Soleyin ULTRA PLA
Hello! I bought the Ender 3 V3 se with Soleyin ULTRA PLA but when i printed with it I could easily separate it into layers. Can somebody give me good settings for Soleyin ULTRA PLA. I am using default settings right now. Also I dont have a filament dryer so maybe the filament needs to be dryed.
Hello @ItzAxol :wave:
Run a search on this forum and you’ll most likely find not too good reviews for this filament. Of course drying it out could help. If you can snap a piece off the end then it usually means it needs drying..
OK thank you for the info i am gonna try that!
Hello ! I had the same issue with Soleyin. The fix was like Jimandyen said, I had to dry it for 20hours ! :sweat_smile:
Where did you dry it?
If it does need drying you can also use a dehydrator but a filament dryer is something you you would have to get.
:arrow_right: Creality Space Pi
Cost a little more but some of these can hold several 1KG rolls:
:arrow_right: Dehydrator Machine
I used the pla that came with my printer and that worked perfectly. I think I am going to order normal pla. But when i get the money i am gonna buy a dryer or make one idk. Also i was thinking does the dryer also make those filament fumes??
