🧩 [SOLVED] Creality Wireless Bridge “Set Password” Pop-Up Not Appearing on macOS (and Possibly Windows)
My Setup: (but possible universal fix)
  • MacBook running CrealityScan v4.1.2.16
  • Ferret Pro scanner with Wireless Bridge
  • iPhone for mobile scanning (used after bridge password setup)
:collision: The Problem
For nearly a week, my CrealityScan software on Mac would not show the “Set Password” pop-up that’s required to enable wireless scanning after Creality’s new Wi-Fi security update.
Here’s what was happening:
  • I turned on my Ferret Pro and Wireless Bridge.
  • I connected my Mac to the Wireless Bridge Wi-Fi network (e.g., Creality_WB_XXXX).
  • The Wi-Fi connection showed as connected, and my Mac clearly displayed the bridge network.
  • But when I opened CrealityScan, the “Set Password” pop-up never appeared, and under Settings → Device Management, it said “No Device” — meaning neither the scanner nor the bridge were being detected.
I confirmed everything else:
  • Software version up to date :white_check_mark:
  • Firmware downloaded :white_check_mark:
  • Reset the bridge :white_check_mark:
  • Rebooted everything :white_check_mark:
I spent six days trying to figure out why the app still didn’t recognize the bridge.
:light_bulb: The Discovery (and Fix)
The missing piece turned out to be something nowhere mentioned in any Creality guide:
Even if you connect your Mac to the Wireless Bridge Wi-Fi, you must unplug the LAN (Ethernet) cable or disable the wired network adapter — otherwise, the “Set Password” pop-up will never appear.
As soon as I unplugged my LAN cable:
  • The Set Password window appeared immediately in CrealityScan.
  • Under Settings → Device Management, both the scanner and the Wireless Bridge showed up instantly.
  • I was then able to update the firmware for both devices and set the Wi-Fi password successfully.
  • After that, my Ferret Pro scanned perfectly via Wi-Fi, including on my iPhone.
:gear: Why This Happens
macOS (and Windows, too) gives Ethernet higher priority than Wi-Fi in the network service order.
Even if you’re “connected” to the Wireless Bridge via Wi-Fi, the system will still send network discovery packets through the Ethernet adapter — where the bridge isn’t listening.
CrealityScan uses local UDP broadcast to detect the Wireless Bridge, so those packets never reach it when the wired interface is active.
Unplugging the LAN cable (or disabling Ethernet) forces your Mac to use Wi-Fi as the active interface, allowing discovery to work as intended.
:white_check_mark: Quick Fix Summary
  1. Turn on WLAN/Wi-Fi on your Mac or PC.
  2. Connect to your Creality Wireless Bridge Wi-Fi (Creality_WB_XXXX).
  3. Unplug or disable the LAN/Ethernet cable or adapter.
  4. Launch CrealityScan → the “Set Password” pop-up should now appear.
  5. Once prompted, set your Wi-Fi password and update firmware.
:brain: Bonus Tip (Optional)
If you’d rather not unplug every time:
Go to System Settings → Network → … (three dots) → Set Service Order → drag Wi-Fi above Ethernet.
That makes Wi-Fi your primary network, so discovery packets always go out over Wi-Fi first.
:speaking_head: Invitation to Other Users
This fix worked for me on macOS with a Ferret Pro and Wireless Bridge, and I was able to resume scanning with my iPhone afterward.
If you’re on Windows and this fix helps you too, please reply to this post so we can confirm it’s cross-platform.
The more confirmations we gather, the easier it will be for Creality to update their official documentation.
:rocket: The Fix in One Sentence
If CrealityScan says “No Device” and never shows the Set Password pop-up —
UNPLUG YOUR LAN CABLE (or disable Ethernet).
It’s that simple.
THIS! Yes! Following these steps did result in a successful connection to my otter scanner. I do think the main issue I was having was the software I had downloaded was 3.3.46, and it wasn’t prompting me to download 4 as the latest version. Then finding version 4 was a little convoluted on Crealitiy’s website.
Thank you for the tip, I was also usuing the 3.6.45 and couldn’t set password for Ferret Scanner. After update it to 4.0 it ask immediatliy for Password :slight_smile: :slight_smile:
PC Still NOTHING! I disabled EVERYTHING including Firewall, VPN, Adapters, Virtual Machine, Ethernet,
Still the Ferret-xxxxxx WIFI wont show up on my PC, SOOO frustrating! Also Yes, none of my devices are on the Ferret-xxxxxx as Only ONE device can be connected at the time, so that’s no the reason why is not showing up.
I see it on my iPhone….which also had issues, but I Finally figure out what my iPhone issue was and why it was giving me the No Internet Connection error…
After installing CrealityScan on your iPhone Go to Setting, scroll all the way down to Apps, look for “CrealityScan” Turn ON “Local Network” ….done!
Make sure the WIFI Bridge led is Blue, Open CrealityScan app wait few seconds, the link will turn Green…HOWEVER you can’t use it because you have to setup the password on the Computer…and mine can’t see the Ferret-xxxxxx Network!
You would think Creality had this fixed it by now, it should be plug-and-play, password should be setup at first app start on the device you are using not on a PC only. no one should get this amount of frustration and rely on other users who experienced the SAME frustration before you.
I am ready to return this thing, this is my last attempt…If anyone has a real solution to this please let me know.
I’m on a MacBook air! I updated the scan bridge(otter) and scanner on the app.. the the popup came to connect to the computer to set password.
I have connect t with the bridge wifi, but won’t show up under devices on the MacBook air (I don’t have a network cable of option on the MacBook air to turn of)
Is there a solution for this to?
Edit: found and used a windows PC to solve the problem within a minute
So it’s a software for the Mac issue
Thank you for the tip.
I had to manually select the light bridge in the available networks tab in Winblows11 to complete the connection but I can now use my scanner in wireless mode.
SOLVED!!! I Finally figure it out!! After a WEEK of Hell!
The Creality Bridge use 2.4 GHz, if your WIFI adapter only work at 5GHz or any other GHz above 2.4…the Ferret-xxxxxx WILL NOT SHOW UP!
Fortunately I had an old 2.4GHz Adapter, after installation I disabled the 5GHz one and voila’! the Ferret-xxxxxx network finally showed up, now it work on my phone AND my PC!
I hope this information help people who experiencing the same frustration.
Creality should be ashamed for letting users deal with hell figuring out why their crap don’t work!
I am still contemplating returning this Ferret Pro due to the time consuming hell and frustration I had to endure.
