Sonic Pad compatibility
Will sonic pad work on a CR-10S Pro v2 with aftermarket main board? I may have bricked my main board after trying to flash factory firmware on printer, and I can’t find a factory replacement so unless I can find out how to un-brick mine, I’ll have to upgrade/replace with aftermarket board. Any help will be greatly appreciated.
As long as you have a pin out and board flash file settings then it will work fine as you can set up custom printers.
