Sonic pad setup - v3 S
I was just looking to figure out how to calibrate the rotational distance on my printer and noticed this in the Sonic pad setup.
Shouldn’t this be set to the sprite extruder?
That is the rotation distance my V3SE defaults to. My Ender 5 plus uses a different figure, but that is for a standard machine not one with a direct drive extruder so I changed it to 7.53mm too. Both machine print just fine. You could calculate it but it will probably give the same answer
I just set my pad up and mine doesn’t show extrusion rotation distance so how do i figure that out? It is impossible to get answers from youtubers who have it on their pads and show how to set it.
