Sonicpad using with NONE usb cam , ip cam stead
i try to use a RaspberryPi Zero 2W as streaming cam with Sonicpad
with bullseye or bookworm
anyone out there who found a WORKING solution ?
my actual solution is:
install octopi (normal version, NOT the one with the new camerastack)
and it works fine.
EDIT, Sorry my mistake: i don’t mean using on the display of the Sonicpad itself, cause that seams not possible, i mostly make use of the pad remotely using a browser.
Actually i found for using the pad remotely i now found a working solution for a pi cam.
so if someone interesting in leave a note here and i will publish it as fast as possible.
