The SPARKX i7 uses an integrated hotend, which combines the nozzle, hotend, heat break, and heat sink into a single assembly. The printer is shipped with a 0.4 mm integrated hotend as standard. In addition, the i7 also supports 0.2 mm, 0.6 mm, and 0.8 mm integrated hotends.
Different hotend diameters are suitable for different application scenarios. Please refer to the notes below for usage considerations for each hotend size.
If you would like to replace the hotend, please refer to the page: i7 Series Quick-Release Hotend Replacement Guide
0.2mm Hotend
Use Cases
Applications that require extremely high surface quality ormodels with fine surface details or intricate patterns that require high printing resolution
Notes
Printing with a 0.2mm hotend will significantly increase print time.
Do not use filaments containing solid additives, such as marble-filled filaments, PLA-CF, or PETG-CF, as they may easily cause hotend clogging.
Flexible filaments, such as TPU, are not supported when using a 0.2mm hotend.
0.4mm Integrated Hotend
Use Cases
A general-purpose hotend suitable for the vast majority of filaments.
Provides good surface quality while offering higher printing efficiency than a 0.2mm hotend.
The most commonly used hotend nozzle size for everyday printing.
0.6mm & 0.8mm Hotend
Use Cases
Compatible with the vast majority of filaments.
Offer significant advantages when printing flexible filaments, such as TPU.
Provide much higher printing speed compared to 0.4 mm and 0.2 mm hotends.
Result in more visible layer lines and a rougher surface finish compared to smaller hotend sizes.
