Why when insert the sd card into my ender3 max,with the 4.2.2 board,the bin file to update the firmware to accept the e steps of 424.9, for the sprite extruder pro,does it turn the language on the display into Chinese. Tried a few times,reexamined the choices,all seemed the same. Ended up having to create a gcode txt file(new to me) then ring a computer shop to learn how to do it and save it,and then put it onto sd card,put into printer,worked. Bin files used to just work.
