I recently bought a sprite extruder pro kit from micro center to upgrade my ender 3 pro and cr touch.
The problem I encounter is that it would work when I first turn on the printer, its does the ABL and first print. When I try to do an an auto home after the first print it would halt and give a m112 error.
Basically the same problem as in this post - https://www.reddit.com/r/ender3v2/comments/mtfxj3/firmware_crash_error_probing_failed/
I did a sanity check and checked the small cable to connected the cr touch to the sprite main board and no problem there.
As seen in the video below I found that 2 of the pins for the cr touch on the sprite main board are shorted together. I’ll go out on a limb and say this is not suppose to be. I used the long cable that came with the cr touch and connected it directly to the ender’s motherboard and it works as expected with no issuses.
Did I get a faulty sprite extruder pro? Is anyone else able to verify this is not suppose to be the case.
Thanks.
