Alarm 8: The cycle failed to clear the limit switch while extracting. Try increasing the extraction setting or checking the wiring.
Do you know how I can solve it?
It seems one (or both) of your limit switch might be defective.
I found this on the Lightburn forum that might help confirm this: Homing fail. Cycle failed to clear limit switch when pulling off - LightBurn Hardware Compatibility - LightBurn Software Forum
I’ve never had this issue (or something similar) myself, so I can’t help directly but hopefully the above article will help you understand and/or fix the issue.
Good luck!
Thank you very much. I checked very carefully and found the error in the limit switch, and it’s working again
Happy it turned out that easy ![]()
