Stop build plate shaking
Hello, anyway to use gcode to prevent using build plate shaking anytime you do a calibration or start printing ?
Thank you
I believe that shaking is part of the calibration to check the four pressure sensors that are part of the bed. I could be wrong, but I believe I am right. If you were to eliminate the shaking, you would also eliminate the ability of the bed to properly detect the pressure when it raises to the print
Oh ok I’m sure your good but there is a problem with that .. Every 4 or 5 print you need to make a new Screws_Calibration or a Bed_Leveling to make your plate good enought to print… Is it only my problem ?
Anyway no solution to cut this, maybe my problem come from that shaking…
I don’t follow. What do you mean that “you need to make new Screws_Calibration or a Bed_Leveling?” I have not observed this issue.I hope you either have found or will find a solution to your problem.
