when I stop a print with pause and restart the print is offset by 2mm. happens every time on a pause.
Hello, I also tried using a pause, but just like in your case, a shift occurs after resuming.
I have a similar problem, but not sure if it related to your problem.. When I place the pause on the Preview layer slider say at layer 8 (1.6mm), the pause in the g-code appears at layer 10 (2.0mm). I’m using the generic 0.20mm Standard@K1C profile with no modifications. Also, as a side note, the documentation says that adding a pause will cause a reset, requiring you to re-Slice the Plate. Not happening. I’m using the Creality_Print V5.1.6.10471 Release.
