Good day. These errors started popping up randomly. The model can print calmly for 3-4 hours, and then the printing stops with one of these errors and then I restart everything, continue, but the error appears again. The latest firmware version for Sonic Pad is installed. Such problems have not occurred before.
I get those occasionally. I have put a ferrite on the USB cable and blocked the 5V pin on the USB, largely it has stopped this.
Please tell me how you blocked the 5V contact?
Ok. Thank you. Im trying for home.
Can probably find a data only USB cable on Amazon/Aliexpress.
I had a similar problem. I bought a ferrite core to clip on the USB cable and it seemed to work. I haven’t had the problem since.
You can buy them cheaply on Amazon but they come in packs of 10 ![]()
As @Bonfireman says, you can buy a USB cable with pin 5 disconnected. It won’t affect data transfer as pin 5 is for the voltage.
Hope you get it sorted ![]()
Thanks for the advice, comrades. In the end, I replaced the regular network extension cord with a normal network filter, where I connected the power supply of the devices and everything seems to be working fine for now.
