Storage card and reader not working?
So I just bought a Ender 3 VE SE, unboxed it, assembled etc. I go to plug the sd card into my pc…nothing…not even a light. i then move to other usb ports, same thing, over and over. the blue light on the card reader flashes but wont stay on. after trying a 2nd computer and recieved the same results, i moved back to my main computer and tried again. The blue light on the card came on, but it’s not registering with my computer. I do have the “100MEDIA” folder but when i click on it, there’s an error of sorts. I read a similar post regarding the same error, however, that person had been able to access the card at some point. Mine is like DOA and i need a 2nd opinion or something, maybe somebody point me at the right place for thier support department
So far, i’m not happy with this machine, the card and a few other things that I am just not liking, so once i get passed this issue, it’s going to be a tough gig to get me to recomend this unit to anyone, including a newbie like myself
Hi
Not sure if new SE models have it, but have you checked the voltage select switch is correct for your country?
When plugged in and switched on does the fan kick in under the printer bed?
Sorry, just read your post again, an I correct it is just the supplied flash drive that is not working?
What happened was the card reader supplied by Creality was absolute trash. Quick run to Walmart for a new reader and this portion of the printer is now working properly
I am confused. What did you do to fix this? Did you have to solder in a new SD card reader? I get nothing from my SD reader or my USB-C port.
