When the table moves all the way forward it hits the top of the printer screen. I removed the screen and run a print which finished ok.
I ve read somewhere that the table is warped and needs straightening, but I found no more info on how can I do it. Anyone can help?
Hey buddy,
The same thing happened to me too — it got bumped once and the top of the LCD frame got slightly damaged.
It’s because you need to push the pin at the back of the LCD screen all the way down. I have three machines, and this last one seems to be slightly different in size compared to the others, so the LCD doesn’t fit tightly in place.
Check to make sure it’s fully pushed down.
Thanks for the reply. You were right, it needed more pressure to insert correvtly the screen.
Do I need to recalibrate the printer now?
