Table size and recommendations for my K2 Plus Combo Plus CFS 3D Printer
Hi, I just waiting on delivery of my K2 Plus Combo and need to buy a set of drawers, plinth, stand or table for it…
Wondering if someone can give me some recommendations:
-minimum table top dimensions… Will it move, shake whilst printing?
  • ideal height of the plinth or cupboard, drawers for filament storage
  • can it be on wheels/ casters? So I can get behind it for the ‘poop’
  • ventilation, I will be using it a second bedroom? How hot will it get? Safety requirements I should consider?
    Looking forward to hearing of your recommendations…
    Thankyou in advance…
If you are putting a CFS on top your table/cabinet needs to be around 300-400mm high.
Top dimension around 550w x 600d.
The printer does shake despite the weight! So something sturdy. Standard desk height is too tall.
Good luck!
When young (er) and LP’s were still played, some that would spend the value of a small car on a turntable, would cut a square hole in the floor and sink a cement pillar into the ground coming up high enough to mount the turntable on … That was “Sturdy”
Cheers.
If you look at my initial posts about getting the K2, i was (and still am) thinking about getting one or two 50mm concrete paving slabs… about 36kg each. As my K2 is on a first floor wooden floor, the deep rumble vibration can be felt/heard almost everywhere!
