[[TE 5029 Problem & Fix]] Any recommandation or support would be much appreciated!
Hello, try resetting to factory settings.
Hello, thank you for your kind recommandation. Below is the list of the methods I2Ve tried:
  1. Resetting the printer
  2. Resetting to factory settings
  3. Checked all the connection wires and points on the head
  4. The other error has had similar symptoms with TE5022 error, so I had also checked the connections and the wires in the bed.
Unfortunately, noıne of them worked out. So, I am returning my printer today. I only have 6h 35 mins printing time. 2 test prints.
It could be something related to software malfuntion. What do you think?
If you have a warranty, you should certainly make use of it; the issue most likely lies with the motherboard—as indicated by the error description, which points to a problem with the MCU (microcontroller). If you receive a replacement motherboard and manage to get the printer working again, you could try to reflash the old board by connecting it to a computer (you can find instructions for this online). You can then keep it as a spare, in case the new board happens to fail down the line.
