My first couple of prints look bad; I am using PLA, and the recommended setting is 200 for the nozzle, 60 for the bed, and speed is about 50% with the fan at 0.
I’m not sure what adjustments I need to make.
Hello @Patrick_Gimor …!
If you are using Creality Print slicer 5.xxx it looks like you might have the “fuzzy skin” setting checked.
I will download it and see if it helps. Thank you
Check the slicer you are using now. I believe most slicers have that setting. If it is selected it will cause the type of finish you are seeing on your models… A very rough fuzzy finish.
