The machine consumable do not match the printed file
I was getting this error too after the update. If you go to the Device section in Creality Print, in the lower right you can change the type of filament that it thinks the spool holder has loaded to match what you sliced your object to print with, and then you can send normally. I think there should be a way to disable this warning. It just seems silly to have to set the type of filament you are using in two different places.
