The Printer head will not lower to the bed, even when leveling
Half way through a print the printer offset the print by 20mm on the X axis, and completed thje print. When I tried to print the object again, it went through heating up, then without moving the printer head the countdown timer started and then completed without using any filament. I Reset the machine, no difference. I tried to level the bed, but the printer head would not lower to the bed. Can anyone help?
This is what mine is doing now, did you ever get it solved?
