Thermistor sensor on ender v2 neo
I have recently disassembled my nozzle and hotend as i was getting a lot of filament leakage. When i have come to unseat the thermistor sensor it was stuck in the heat block. After trying to gently remove it, I am left with this
20250305_145929|233x500
I want to either repair it, or replace it. but my searches in replacing it are no good and i need some assistance.
I don’t think that you will be able to repair it, but you should be able to get one off amazon or Aliexpress just got to match up the connector at the other end. When fitting the thermistor the location screw should be barely pinching the the wires, they are easily broken. Keep at least one spare.
