I clicked on Timelapse Video in the Device windows, there is one Gcode name:Creality+USB+Port+Dust+Cover+V.gcode its size is listed as 6.25MB, Video Name: /usr/data/printer_data/gcodes/600S-TEST-7m.gcode:3923399:/usr/data//creality/userdata/delay_image/video/1704328437.mp4:0:/usr/data//creality/userdata/delay_image/cover/1704328437.png:1704328437:568:
Start time: 1969-12-31 17:32:52 Print time: 473424h 33m 57s
When I delete the job nothing happens.
How do I clear the junk out of memory?
Tell us what printer and software you are referring to so someone else having the same problem might be able to offer a solution…
This is the Creality Print Timelapse Video list in Windows:
When I click on the file name a menu appears with a delete option. I click delete and the file is gone…
I click delete and nothing happens… I tried Rename, but the same information keeps reappearing
Is that a file that came with the printer…?
If it is it might be written into the firmware and you can’t delete.
Otherwise I’m not sure why you can’t delete it…
That file came from the Creality Cloud, I printed a USB plug for the K1.
I just ‘Upgraded’ the firmware from 1.2.9.21 to 1.3.2.20 but the Time Lapse window still shows that broken file. I exported it and viewed the USB plug being printed but I still can’t get it to delete the job and with that broken job listed I don’t get anymore Time Lapse!
When I went to setup root access I noticed a new menu option:
Reset to Default
After setting the K1 up again the Time Lapse file was gone!
