When I print my file out the support on the print is always so hard to get off. I tried lowering the density but it still is the same! Is there any better way to make support or material?
What slicer are you using…?
If you are using Creality Print I might be able to look at your settings and help hopefully… ![]()
Which slicer? I tend to disable support roof/interface, it doesn’t adhere so much.
Creality Slicer version 4.3
try creality print perhaps but if you can disable the support roof/interface it makes a big difference.
I’m using Creality print 5.1.6 and I’ve got issues with having a clean overhang after I remove the support. One recommendation in an earlier post was to disable the Support roof/interface. I can’t seem to find that in the menu.
Anything beyond that recommended?
