While printing TPU, I tried to keep all speeds in a really slow setup. From 10 to 25mm/s. Whats been happening is that the printing is usually ending 30 - 50% faster than the estimated time AND the issues of printing TPU are still there, always. Hence I believe that somehow the K1C is printing way faster than Im telling it to do.
Any clues on how can I check and correct it? or any other tips to improve TPU printing in K1C? its the most commong TPU tipe, I guess… 95D or something close.
Thanks
I noticed there is a setting for minimum print speed. It is usually at 20mm/sec.
You can alter it…
Seth
Thank you @For_Ward , I actually did it. created a profile for the printer, not just the project itself, with all speed limits at the minimum. Got the same results.
Let me show you… It may be easier for me to show some photos.
Center of page, Min print speed 20 mm/s.
Seth
P.S. @_Crivelare , I think, not know, that the Min print speed is a bare minimum for settings elsewhere. So, if you change it in the main screen for say complicated cornering to 15mm/sec, it will not listen because of the Min print speed is 20mm/sec. I think that is how it works.
