TR2863 pomocy!111
Mam problem z błędem TR2863 co kończę drukować wywala błąd TR2863 rozkrecam ekstruder przepycham drukuje dalej konczy i znowu itd pomocy!!!
Tomasz, my polish is translated through google so if I am not on topic let me know. but I think you are experiencing a recurring extrusion failure. You are running a K series print, correct? Is this the only error you are getting. This error can be caused by a couple of issues.
Heat Creep: If the hotend is getting too hot and heat is traveling up into the cold end (due to high ambient temperatures or a failing cooling fan), the filament can soften and jam before it reaches the melt zone. Are your fans on the extruder working?
Bowden/Extruder Resistance: Debris or a worn-out path inside the extruder assembly is catching the filament. How many hours do you have on the printer? have you changed out the tubing? Have you disassmbled and clean the extruder? The smallest pieces of filament/debris can give. inspect all the gears
Cutter/Sensor Issue: If your printer has a filament cutter, it might be engaging at the end of a print and failing to reset correctly, causing the “jam” upon the next startup. If you have a cutter it might need to be cleaned or replaced.
Let me know how you make out.
Mac 486
Hi, the printer has 320 hours of use, and it works like this: It prints an object, finishes printing, retracts the filament, and throws an error. I have to unscrew the extruder and push the filament out. The light goes out, and everything is fine.
