Transferring custom filament settings from slicer to printer
Hi all, is there a way of transferring my custom filaments settings from the slicer (C.P.6) to the printer, so I can select the correct filament at the printer touchscreen, and it’ll use the correct settings when printing a downloaded model directly from the printer touchscreen? I’m a long-time 3D printer, but only just started with the K2+, so still learning the new slicer/printer configs.
NO, The printer selection is either Creality or Generic. That is it.
I ensure I select the filament for the object before printing to ensure correct parameters as all other visual references point to printer parameters.
It would be a great idea if you could synchronise the printer with CP6 though
Thanks for your quick reply, Mrburns. I was hopeful because I noticed my printer has added an “eSun” option to the vendor dropdown on my printer filament settings. This leads me to believe there’s a way to edit one of the (many) klipper .cfg files in the printer O/S. I’ll obtain the root login password and ssh to the printer CLI, then have a look around the config files. If I do find a way to manually add custom filament entries to one of the .cfg files, I’ll let y’all know. As you say, wouldn’t it be nice to have a “click to sync” button on C.P. to sync the settings into the printer (wouldn’t be hard to do).
That Esun appeared in the last Update, if I remember right.
One of the software people appeared in one of the threads a couple of days ago.
I am going to ask him if filament synchronisation can take place.
You might want to check Filament Sync .
Oh WOW - that’s EXACTLY what I’m looking for! Thanks a lot for the link, Costas-anon - I’ll try it out and report back. Thanks again!
Any luck getting this working? I just got the CFS for my K1 Max and I have a few custom profiles I have pretty well dialed in and the stock settings aren’t great for everything.
Thanks!
