Trouble extruding
I’ve recently gotten my hands on an Ender 3 v3. So far I’ve been able to print about 3 rolls of filament so far. Just now I’m running into my first issues. It started with my extruder making a tapping noise followed by the printed failing to extrude at some layers and parts of the print.
My first thaught was the extruder assumably. So I’ve taken it out and cleaned it multiple times. No stuck filament or broken part was found any of the times.
My second thaught was wet filament but after swapping to a new roll 2 times with the exact same result and printing the initial roll on another printer with great results I think I’ve ruled out wet filament.
Now the printed won’t make the tapping noise but the print quality is very poor and I can see clearly how it from time to time fails to extrude properly and parts lines are missing on walls and surfaces.
My last effort to diagnose was to print the test file already on the USB stick just to remove my own slicer settings from the equation. The test print suffered the same quality issues with some layers missing lots of plastic. It was very visible while printing the infill which was more of a web inside the structure rather than the square net. It also dipped down in temperature to 195 c rather than the 215 it was set to print on.
My next step will be to swap the nozzle and see if there might be a partial nozzle clog.
Any ideas are welcom!
Hi
I would first of all ensure the tension on the extruder is ok.
Extrude some filament, say 100mm then retract fully. look at the extracted filament and see if you can see teeth marks. You are looking for some marking but not too deep the “Goldilocks” zone.
Next calibrate the extruder, not sure how on your model (I have a SE) but google is your friend.
Also the temperature dip is a bit concerning, a nozzle change may work, but I would be more concerned about the heating side.
Hi, after 1st printed roll, I had some problems during the printing. First I also think about nozzle clogging. But extruder gears bearings were out of order. I order on AliExpress gears for x1c (same as 3v3). Disassemble extruder gear, and check tooth and bearings, an motor as well.
I’ll have a look at the extruder. If it’s lose I might have to replace it. There is no way to tighten the gears unfortunetly. It’s the same extruder as the K1 mounted in the print head. I’ve swapped the nozzle for a high flow one which helped a ton. Now I guess most of the slight underextrusion is due to it being a highflow nozzle which I’ve not yet tuned it for.
The gears seemed fine when I had it apart. Did you get the all metal gears? Other than the nozzle change I’ll tryt to mount the filament on top to make it easier on the extruder. It has to bend an awfully lot now to make it into the bowden and away. Next steps will be an extruder gear upgrade or replacement.
Hi, yes both metal gears with bearings and notches for filament . It is not best idea make console construction how it was made for be broken.
