I can’t seem to print apparently because I’m trying to use a non-Creality filament, Matterhackers NylonG.
First, can someone help me set up this filament in my CFS correctly. There does not appear to be a way to create a new filament name and setting. At present, I have just selected PETG-CR as it’s nozzle and bed temps are closest to what I need. Matterhackers recommends 255/65 for this NylonG filament.
Second, when i try to print, the CFS display tells me that “Filaments marked with “…” require manual selection of a CFS slot.” But it will not let me select the #2 slot where the filament is located. I suspect this is because the first issue above needs to be addressed first.
HELP!!! Thanks in advance!
John
