Trouble with X Axis
:sob:Hi, i ordered my Falcon 10w on July
I have been having problems lately with the x axis.
I use Lightburn, each time i try to cut, the x size changes
For example, if i draw a rectangle 200mm x 10mm, the X side ends up being 210mm
I go to lightburn > Machine settings > Calibrate Axis > X Axis
Draw again and… still wrong
I repeat the same process over and over, first draw a rectangle or square then change the X axis on Lightburn then draw a rectangle, then change again on lightburn and again and sometimes it ends up being the right size, BUT the next shape that i try to draw is wrong size again
This has been happening for a long time, i tried to tighten and untighten the belts many times, sometimes looser, sometimes tighter
I don’t know what else to do !
