Creality’s Wiki and their YouTube channel have a lot of very good guides for Maintenance, but they are very definitely “Maintenance with a big “M””.
I wondered if there was a guide that included more simple fixes like “how to fix a filament jam without losing your print”
The CFS as everyone knows is very hard on filament; plus with the “double clutch design”, the filament grip on the front of the case and the one where the filament exits the CFS are so badly spaced and so hard to depress that freeing filament that the CFS has shredded is a very difficult one man job.
Having had this problem several times, I think I have the “knack” of it, and it suddenly struck me; why is it I can find out how to replace the CFS hub, but not how to simply clear it?
Am I missing a section of the Wiki or some other source where this actually exists? If not, is anyone intersted in starting to collect knowledge for this?
I don’t know if this will help. I went to CoPilot and asked the question for the K2 Combo and this is the reply:
A jammed CFS Hub on the Creality K2 Combo is one of the most common early‑use issues, and thankfully it’s almost always fixable without disassembly. You can walk through this like a controlled mechanical recovery—clean, methodical, and safe for the hub’s gears and filament paths.
Below is the stepwise, technician‑style workflow that reliably clears a jam without damaging the hub or the AMS‑style selector.
How to Clear a Jammed CFS Hub (K2 Combo)
1. Stop the Hub Immediately
Power off the CFS (or the whole printer if needed).
This prevents the selector motor from grinding or skipping teeth.
2. Open the CFS Top Cover
Lift the lid to expose the hub selector wheel and the filament entry ports.
You’re looking for:
A filament that didn’t retract fully
A filament bent at the tip
Two filaments trying to enter the hub at once
A filament wrapped around the selector wheel
3. Manually Rotate the Selector Wheel
With power off, gently rotate the hub’s selector wheel by hand.
You should feel smooth detents as it indexes between ports.
If it binds:
Reverse direction slightly
Try again with small, controlled movements
This often frees a filament that’s wedged between the wheel and the guide channel.
4. Remove the Stuck Filament
Depending on what you see:
A. Filament tip stuck in the hub
Grip it with tweezers or needle‑nose pliers.
Pull straight out—avoid twisting.
B. Filament bent or mushroomed
Snip the damaged end clean.
Pull it out through the spool side if possible.
C. Filament wrapped around the selector
Carefully unwind it while holding the selector wheel steady.
Do not force the wheel—this can strip the internal gear.
5. Clear the Internal Channel
Once the filament is removed:
Use a small piece of straight filament to “probe” the channel.
Push gently through the hub path to confirm it’s unobstructed.
If it catches, withdraw and try from the opposite direction.
6. Power On and Run a Retraction Test
Turn the CFS back on.
Use the touchscreen to:
Select the affected slot
Run Load then Unload
Listen for:
Clicking
Grinding
Stalling
If it still binds, the selector may be misaligned—repeat the manual rotation step.
7. Prevent Future Jams
These are the big three causes:
Filament tip not cut cleanly
Cut at a 45° angle before loading.
Moist or brittle filament
Your CFS desiccant routine is already solid—keep that going.
Filament too stiff or oversized
Some brands of PLA+ and PETG are slightly oversized and catch in the hub.
