Hello everyone,
This is my first post, hoping someone can help out.
My Ender-5 S1 with the Sonic pad has been working great. Last night I turned it on to print something and there was an update available on the Sonic pad. I did the update everything went fine. I loaded a file in the Creality slicer and sliced it as I always have. Put the sliced file on the same USB stick I have always used. Went to print, and it loaded and showed the image of the item to print, hit the print button, and nothing. Rebooted everything twice same thing. The other thing was when I added the Sonic pad when I bought the printer, the original screen on the printer was always dark. Now after the Sonic update the screen on the printer comes on and says calibrating. Any help would be great
It sounds like something has glitched out somewhere, I would recommend reflashing the klipper firmware generated by the Sonic Pad to your printer to ensure the firmware is operating as it should. I have recently received the update and my printer screen remains dark.
Thank you very much for the response. How do I reflash the Klipper firmware to to printer? I did it a year ago when I bought the printer and Sonic pad together. I have no idea how I did it now. The screen on the printer always stayed dark until I did the update. Thank you again! Craig
In theory you should be able to pick the printer on the Sonic Pad to initiate the firmware install for the printer.
I have just checked the manual for the Sonic Pad and it looks like page 9 section 2.7 on-wards should cover the process for updating/installing the firmware.
Hello, I did the reflash and still get the same thing. I slice the file and download it to a USB memory stick. Put the memory stick in the sonic pad open the USB stick load the print. the picture of the part comes up like it always did. Press the print tab it says loading for about 2 seconds and that’s it, printing doesn’t start. I have probably 20 sliced files that are on the USB stick that before I did the update loaded and printed fine. Now only 1 of the files will load and initiate printing. This is very frustrating. I have a bunch of stuff to print. Hopefully, you have some ideas.
I have been seeing several reports about issues with printing from USB so I get the feeling the issue might be in the firmware itself. I will keep monitoring the situation and if I come across a fix I will certainly let you know. For now I would upload the files to the pad via the web interface and print from there.
I too have the same problem, cannot print on Ender 5 S1 from the Sonic Pad. My print environment has not changed from when it worked perfectly. I have been dealing with this for over a month…very frustrating. The printer does just fine without the pad attached, but that is WAY clunky. I have restored the pad to factory and/or restarted Klipper more times than I can count, have flashed firmware 3 times on both the printer and the pad, ran the self-test (30 minutes!). Each time, at the end the printer self test says that everything checked out, printer is ready to go. explore, and the like. But when I plug in a USB drive and try to print the Sonic screen shows “loading”, then just “blinks” and the “PRINT” button lights up again…then nothing. I have tried to print both new jobs, and jobs that have printed perfectly in the past from the same g-code. Thinking maybe it slicer was at fault I tried two other slicers. NO GO. I’m thinking firmware issue. Whatever it is, can we get this fixed ASAP?
Have any of you tried printing my LAN or WiFi just to check it’s not a USB issue? My Sonic Pad is on LAN and no file issues at all. Blank screens, but that’s because the pad has taken over proceedings.
Hi did you ever figure out the not printing from USB on the Sonic Pad? I have tried brand new memory sticks, formatting them as per Creality. Very frustrating.
I am having the same issues. I printed multiple cookie cutters without an issue on Saturday. Went to print more the next morning and all I get is “loading” nothing prints. I am able to print items on the cloud, but not from my USB. I even went and bought a new USB and that won’t work either. I’ve even done a factory reset and no changes.
I was having the same problem and I tried everything redoing the gcode over and over but it turns out I had to delete the spaces in the names of the gcode files stuff like “Three-Point Connector” won’t work but “Three-PointConnector” will!
I have the same problem with Ender Max NEO. I tried everything then did a factory reset and still could not print from USB. The new firmware update was horrible. The only way I found to print is to transfer the files to local from the USB stick then load.
Same issue and still trying to figure out how to revert back to old software since Creality seems to have no desire to fix this last firmware update from a year ago
Has anyone been able to rollback there Sonic Pad’s firmware to a previous version or successfully performed a force factory reset to the default firmware v1.0.6.43.
Has anyone contacted Creality support talking them about this issue and asking them to release a new firmware update to fix the USB issue?
