Upgrade to a silent fans
Hello everyone, I have my k2 pro for couple of weeks now and a main “problem” is the noise of back fans, as I leave in small apartment with wife and kid and most of the prints go into the late night.
I had a look at Noctua fans but don’t find anything, back fans are one 60mm 24v and one 80mm 24v.
Someone already did this upgrade?
Thanks
Witam,
Czy udało się przeprowadzić modyfikację?
Hello RazvanBosman , you can get quality silent fans on Amazon. Do a search for “80mm Silent Fan 24V” or “60mm Silent Fan 24V”, It will help with the noise issue, but as soon as the huge auxiliary cooling fan kicks in, you will experience that jet turbine sound, and you can’t swap that fan. The only thing you can really do that would make a big difference is to build a closed chamber for the printer, but it has to have a controlled environment with some silent fans, as the printer doesn 't like heat. I hope that I 've helped you. Merry Christmas.
Why can’t you change that one?
