I’m running this version on Windows and I cannot print a newer file. When I load and print a file, it sends the last file to the printer, not the file that is in Creality Print’s “View” tab. I have to restart both the software and the printer, to clear it so the model I want prints.
Same here…
Hello saline and GLEN_REDMOND,
Advise would be to not use version 6 until Creality has it confirmed that it is infact Stable.
If you check elsewhere you will find MANY people having MANY problems with Creality Print V6.
It would be best to use either version 5.1.6xx or use Orca (which is what
Creality print is modelled from).
Cheers.
How will we know?
Version 6.0.3.1591 has arrived with some of the issues fixed.
Bill
I haven’t had too many issues with CP6. Recently upgraded to 6.0.3.1591 and not really a lot of change from 6.0.2.
I’m going through the source code to see if I can tweak things, especially around the UI. Put scale back with move and rotate, save the Ui layout etc, but from a print perspective it’s been pretty good. I notice things like arc fitting enabled by default even though it’s tooltip says it should be disabled. This made one of the prints messed up in the bottom half and is easily fixed by modifying the profiles that Creality provide.
I’ve had the same problem, my solution is to send the file to my printer then select the file from the printer screen.
This version close when i slice my models. Very irritating when it close the whole time on the computer. Even deleting the version and.use 6.0.2 did not help. Going to Orca for now, till they fixed it.
Ditto. I am using v5.1 until this irritating bug is squashed permanently.
