Warning!!! KEY:2000 error
Folks,
My printer is not even a month old and is giving me issues, it stops multiple times in the middle of a print with
KEY: 2000. “ an unknown error occurred during printing”
I can’t recover from that error, it doesn’t respond to anything. Have to power cycle in order for the printer to go “Home”, so I can clean the bed. Some times it doesn’t even resets (does nothing) after a power cycle and another error message appear with this message
“Spray Head motherboard communication error, scan QR code and contact creality”
Tried everything suggested on the QR code link, but still doing the same. I tried also different files, just in case the file is corrupted and it keep faulting out.
What you guys will suggest
Its sound like cable loom is damaged.
Hi, were you able to get things working? If so would you mind describing what you did?
Thank you.
