Hi, First time I joined in any 3d printer forum, but this is driving me crazy. Machine is around 2 weeks old, its been mostly printing small models, I’m using the old Creality Print, Slowly changing to the new V5.
So I decided to print a toolbox, for all these tools im getting. Started printing the lid, its quite large covering most of the bed, Using a PEI (Gold) building plate, so not had any problems with models sticking.
Last night the 2 hour print had almost finished when I noticed both corners were lifting, nothing I could do, 2 h and a lot of filament wasted.
Hyper Pla
Fast
No Raft
Never used glue before on this new PEI double sided sheet
Only parts about 100 mm x 100mm and less, first time to use a much larger model K1 Max Tool Box, was printing the lid.
This morning I decided to put some glue of the PEI plate, not something thats done, but Im trying this just to see what happens.
DO I need the lid off, and door open? Never did this before, but a new Printer I just bough for the wife (QIDI Q1 Pro) insists if you use PLA you need the lid off and the door open?
Just one thing, I just fitted a new nozzle just before i printed this lid. It all got clogged up, needed to dismantle everything to change, fitted new nozzle, tested with Benchy, all ok Don’t know why, it was printing some flowers
all printed ok, then i switched off the printer, few hours later tried to print, all clogged up?
The Lid and tool box both have a large flat aria, the lid was all flat when the problem started, it was about to print the corners, up until then it was flat
Update
Glue covered, tool try part, if finished, but still warped. Now trying it again, this time with a raft. 5 hours time now in UK 2:08
