Creality says to use WD40 Specialist Silicone Quick Drying to lube the belt rollers inside a K2 plus. I can not find this and both Home Depot and Lowes SKUs point to the “Long Lasting” version even thought they show the picture of Quick drying. Does anybody know if the long lasting is OK to use? Or maybe they changed the product and now this is what its called. Thank you for any responses.
WD40 Silicone Quick-Drying.pdf (366.5 KB)
WD40 Silicone Quick-Drying SDS.pdf (235.7 KB)
Depending on where you live. The local Home Depot or Lowes may be restricted from selling it in your state.
However, even with chemicals I can no longer get in stores, I’ve found that these restrictions do not apply when you order them online.
Here are the raw links to the online purchase so that this forum software bypasses their bot checks.
1. https://www.homedepot.com/p/WD-40-SPECIALIST-11-oz-Silicone-Quick-Drying-Lubricant-with-Smart-Straw-Spray-300012/204500174 2. https://www.amazon.com/dp/B00631GSSI 3. https://www.walmart.com/ip/WD-40-Specialist-Silicone-Lubricant-with-Smart-Straw-Sprays-2-Ways-Twin-Pack-11-OZ/2901055921 4. https://www.lowes.com/pd/WD-40-Specialist-Specialist-oz-Water-Resistant-Silicone-Lubricant/3503050
