When I do self check I get error 2522
Hello @wayne_levesque …! ![]()
I believe it has something to do with the leveling sensors. If you do a search for “error 2522” there should be some discussions about it on this forum.
I’ve had that error before on my machine when it was new. It hasn’t done it since for some reason after firmware updates and some resets.
If you are doing a calibration and notice the bed start to go all the way down (not supposed to do that) to the bottom shut the machine off.
When mine did that it would come back up and the nozzle would crash into the build plate…
Hi there, in my case this 2522 error in my K1C was a One strain gauge as broken the resistence are open the others 3 are 1k ohm and this are a 2k ok no way i have to print I carefully remove the white like a glue protection on lias cell 3 dots open I dont know the origin but ok after iron is hot I soldered 3 ways o flex cable bridge load cell at circuit I used as zoom of cell see in the pictures.
![IMG_6896|375x500]
(upload://7YnCzt0A2MC82SoQqwT37sZ5LkG.jpeg)
Now I make self test and go Back to work. Just share my fix before the hammer fix forever tool trouble. Regards.
Nice job keeping the hammer on stand-by! +1
Saludos, quisiera compartir mi experiencia, muchas gracias tenĂa error 2522 me diste esta idea de revisar los sensores uno x uno y me di cuenta que habĂa uno exactamente mal soldado lo repare y ahora mi máquina está como nueva , gracias x el aporte me funcionĂł bastante
