I think Creality need to cheeck this or it would be great if i could skip steps of the calibration cycle:
Like the nozzle going down the flex part of the magnetic textured bed I’m talking about the sequence where the nozzle moves to the middle of the flexible metal part (because there is a hollow space underneath that section). Where the nozzle gets cleaned—not the wiping sequence where it drags the nozzle across that metalic flexible section. I mean the sequence where it simply travels to the middle of that flexible part, lowers, and presses down hard, slightly bending the bed (which is made of plastic). I don’t understand why it does that; I get the wiping part—it doesn’t apply much force there—but when it “calibrates that zone,” it presses down forcefully in the center.) Why does the nozzle have to press against that part with so much force? it could break the bed or plastics the bend is hard, you can se that part of the entire bed bending down a little. i tought with the new firmware (1.1.5.4) this sequence will be gone, but nope, still does it.
It does that after the cleaning nozzle sequence
