Will someone help me? Ender 3 V3 CoreXZ stuck on the root screen
Hello, creality print has been updated to version 6.0 and I sent the first gcode to my ender 3 v3. After sending it, the screen froze and I thought that if I turn it on and off it would be fixed. When I turned the device off and on again, it got stuck on the creality screen and does not open at all. I tried to reset it with a USB flash drive but it does not see the USB. I tried to connect with SSH but it does not connect. I am trying to access by adding :4408 to the end of my IP address with Fluidd but it gives a network error. What should I do? I would be glad if you could help me.
Can you ping the IP address of the printer? Did you have it rooted before trying the reset?
No, my device was not rooted before. Currently, my printer is connected to Creality Print via wifi and I can control my printer with Fluixd.xyz. But I cannot use the device screen. I think I need to reset the device but I do not know how to do it without the screen.
Hello eren_Karagul,
Can you re flash the firmware for your printer. (the .bin file)
If you need to download the firmware.bin file, I probably would not get the very latest, maybe 1 version back.
I would also ditch CP version 6.0 and go back to version 5.1.7xxx (if not, give Orca a try).
Cheers.
I’m trying to do it like in this video, but my printer doesn’t respond at all. (I’m using the printer’s own flash) https://www.youtube.com/watch?v=F1ph6eSIgko&ab_channel=CrealityAfter-sale
