Would be possible to daisy chain multiple 3d printing robots?
What would happen if you would be able to daisy chain multiple printers and all the printing capacity, and area would be combined or used under different tools? Aka prototype line, manufacturing line?
One Chassis printer, one pcb echer, one AOI, etc….
Zoltan
Sure, you can do that. It is more of a “hub” than a “daisy chain”, except that you can not combine print area. I’d put all the machines on the same network and assign them to the same control software (Creality Print-6 for example). Then set up the print task and sequence in the software. A lot of business run on that approach. If you are up for some coding, you can even automate the process a bit.
