X Axis moves to the right continuously and print wont on center - all limit switches fail
Added WD40 to some lubricating points, now when I go to auto home or extrude it moves all the way to the right and continues to move for a about a few seconds. When I print it is off center. It was fine until I sprayed the WD40, the belt tensions and eccentric nut is fine. Moving manually everything moves correct, if I touch a limit switch, it still continues to move, I have also replaced the motherboard. The cables are not backwards, any other thought? Video attached.
See the link IMG_0760.MOV
Same problems here.
