Y offset to Z axis when printing
Hello.
After calibrating my filament, I have now printed 2 larger objects.
Both objects are put together. Unfortunately, I had to see that the angle between the Y and Z axes was not correct (pressure diagonally upwards at the back).
The angle between the X and Y axes is correct.
Printer “Creality Ender 3V3 KE”.
Englisch
I checked the angles between the y and z axes.
And the Z-boom tilts backwards. To the printing plate as well as to the frame.
How can I adjust the boom correctly since it is only attached from below with 3 screws?
At the top of the Z leadscrew is a collar on the pulley that drives both leadscrews, on the right hand one loosen the grub screws you can then manually rotate that leadscrew to level the X gantry. Place 2 equal size things ie can of beer or gluesticks and adjust so it is level, retighten the grub screws. Or is the Z axis not square to the bed? I fitted some gantry supports to get mine square, that’s my V3KE but it is the same on my V3SE.
Thank You.
How did you attach the holders to the front of the case?
Just hole in the housing and screw the nut through? Or a counter plate inside?
Right hand side it uses the existing mounting holes. Left hand side, drill, screws and nuts. There are other gantry supports/mounts available on Printables/Thingiverse.
