Yestarday i connected my cfs and everytime it want to switch colors it pauses and doesn't change color
Now I have seen on the Internet this might be because of humidity (my HR is around 40-50) which is medium humidity from what I understand, is there a way to override it or maybe change the threshold?
Its your gcode in the slicer. I had the same issue. Are you using
creality print or orca slicer ? In creality print check the gcode for filament change. It may have pause or m600. You need to use the system machine options and copy to your user versions.
i use orca slicer, i will check and update,
thank you
Okay I found problem I had, in the printer setting in the slicer - go to machine G code - search change filament Gcode - if pressed paused delete it and don’t replace with anything.
Also look in the printer setting - multimaterial - look for manual filament change and uncheck it
