Z offset and Fluidd
Has anyone adjusted Z offset through Fluidd? I noticed when adjusting with the up arrow when saving changes the setting to a negative number and visa versa. I am afraid to do any adjustments without knowing which direction the bed is moving. I am having issues with the nozzle crashing into the build plate after initial bed leveling when starting a print. My printer is not usable at the moment except for being a build plate engraver.
@justpassntime , I responded on your other post as well. Normally In Fluidd (Assuming coreXY printers like the K series) the up arrow actually lowers the bed away from the nozzle, and the down arrow raises the bed closer. So kind of counterintuitive from what I understand🤣. After you’ve done your main probe calibration and saved it, as mentioned in the reply to your other post, you can use the arrows during the first layer to make tiny adjustments. If you want to make those adjustments permanent, run Z_OFFSET_APPLY_PROBE and SAVE_CONFIG afterwards.
