Well I have tried it many times but I cannot get a decent print with 0.1mm fine defaults. Always grinds into other layers. 0.2mm is absolutely perfect. I must be missing something obvious.
I’m wondering what other settings to change if you are using the .1mm…?
Maybe lower the flow rate…? Would too much cause grinding…?
Hmmm…
Can you print a .15?
Yes no problem with that. Considering the amount of printing I do on the SE, continuous, it probably needs a new nozzle.
