Hi, just look to the Ender 3 v3 se datasheet for the motherboard. Can i know the amp rating for the 24v port on the motherboard?
Hello @Luqman_Hakim
Welcome to the Creality Forum. Thanks for joining… ![]()
Not really sure if this is what you are looking for. ![]()
It looks like the power supply is 350 Watts.
Thanks for you reply. I mean the port on the motherboard. As you can see in this picture there is a port with 24v output
IIRC the power supply is rated at approx 15 amps. Not sure if this is the same for the 24v DC port though, you would need to ideally check with a multi-meter.
are you talking about the bottom left where it says DC24v?That is the 24 volt input for the printer FROM the power supply… there are extra spaces for 24 volt connection on the power supply itself if needed
Do they use the same motherboard for the KE
