I have a Creality Falcon converted Ender 3.
I have 2 issues, when pressing home the bed moves all the way to the front and then tries to continue on and the whole machine rattles. How do I reverse this direction so it finds the microswitch and the rear.
I have the bed size set at 230x230, how can I adjust the bed coordinates so that the laser knows exactly where the 4 corners are
Many thanks
Open the console in LightBurn or LaserGRBL.
Check current configuration with $.
Find $3, which controls axis direction:
- 1 inverts X-axis (binary 00000001).
- 2 inverts Y-axis (binary 00000010).
- 4 inverts Z-axis (binary 00000100).
To invert the Y-axis:
- If $3=0, type $3=2 to invert only the Y-axis.
- If $3 has another value (e.g., $3=1 for X-axis inverted), add 2 to invert Y too.
For example, $3=1 becomes $3=3 to invert both X and Y.
Send the command (e.g., $3=2) to apply the change.
You can set the work area in the laser’s profile in Lightburn.
