Hello! I just bought my first 3d printer, Ender 3 V3 KE. I assembled it, made sure it was on the correct voltage and everything. When I turn it on, the screen comes on, I can choose language, connect to wifi, everything, but during the initial self test, it will get about halfway through, then suddenly just restart
I would check the PSU or motherboard fans are running. My Ender 5+ had a problem fan that would cause something like this. There are 2 fans, one blows on the motherboard and one that is built into the PSU. I put a bigger fan on my Ender 5+ and am thinking of doing the same on both my SE and KE, aiming for better cooling and less fan noise.
It must be under warranty, you should contact the support
Check the voltage on the back. It’s a little red toggle switch in the back of the printer. I had the same issue because mine was set to 230. It needs to be set to 115. Mine worked just fine after switching it. Refer to instruction 3.4-4 in the Quick Installation Guide.
Thanks a ton!! This worked for me!!
Thank. That pesky little voltage switch was my issue as well!
Having the same issue. All the steps work until the leveling then it just restarts the process all over again. I have to get this working. I will try the power toggle in the back and see if that works. Thanks everyone.
Several monthes late but tysm this worked flawlessly
I love you man! Was loosing my mind over this issue! Worked just fine after switching it to 115v!
Awesome support! thkns a lot! ![]()
I had the same issue! Thanks so much for this - I missed that in the instructions since I’ve used a V3 SE, but hadn’t set one up so once I got to having it assembled and plugged in I wasn’t looking at the quick start manual anymore. Silly me, I thought I knew what to do. ![]()
