Hey all
We’ve just bough an ender-3 V3 Se. On startup it goes into the auto z offset calibration - the head rises about 10mm and then stops and nothing else happens - the screen is unresponsive.
We’ve reinstalled the firmare -downgraded to the older version and still have the same problem. then upgraded back to lastest version but it still crashes.
Have checked all motor cables are plugged in correctly.
Part of the procedure is move up 10mm then deploy, any homing will do this so it doesn’t try to deploy into the bed and bend the pin if stopped close before.
Check the connections for the CR touch make sure it’s okay
We managed to trick it into moving down by pressing the x axis limit switch, then the probe will deploy and detect the bed, but on the next movement down it crashes into the bed and will damage the head.
Where are the CR touch connections you mention?
And thanks for the help!
Bry
I wondered if that was the case - is it supposed to do an x axis calibration before doing the Z?
I’ve already checked the cable and connection and it seems ok.
Yeah I don’t really look at it anymore but it does y x then z.
Potentially could be the motherboard side the called is loose. I would double check all connections to be honest shipping does sometimes take a beating to items no matter how good they are packed.
I’m pretty sure my last delivery was drop kicked from a speeding van towards my house
Hey did you find a solution to this? I’ve just set my Ender 3 V3 SE up for the first time, running the auto z offset procedure and the motors are making horrible grinding noises then the nib just presses into the bed. The probe isn’t even over the bed so it can’t detect when it hits it.
theres a square hole in the back with a voltage switch. was just having the same problem flipped that switch tried again and its working fine now. try that!!!
May have just been me, but I did not realize that there was foam under the heating bed that should obviously be removed.
This prevented the initial steps from running.
If you hear a strange, loud noise when the heating bed moves back during the initial run then you too most likely did not realize that there’s foam under the bed.
Switch the printer off, remove the foam (two pieces) and restart.
