Build plate issues
I’ve been using the original build plate for my SE and it’s worked pretty good.(All pla)Prints stick nicely until the bed cools and then they come right off . I bought a second plate (identical to the original)and every print sticks like it’s been super glued to the plate. It’s a real bear cold or hot. I know I can use glue stick but the difference between the two is crazy. Any thoughts on how to make it less sticky? lol. Thanks in advance
Hello @Steve_Bertsch :wave:
Actually in some cases the glue stick will keep the model from sticking too much. I normally don’t use glue and just clean with alcohol but using PETG I use glue as a release agent.
In your case it might work as a release agent. Might help..
Hi
I would advise changing out to a PEI sheet, these are readily available (Amazon, Ali Express etc) for not much money and make the world of difference.
Yeah it crazy that the plates act so different even though they are identical.(i always use IP Alcohol to clean between prints) i guess ill have to use glue on the new one. thanks
PEI…Best thing I ever bought for my printer.
