Since the glass bed is thicker than the factory bed, can I use the same procedure to level the bed, ie auto home, disable steppers, etc
I have used the glass bed on my KE. I added an adhesive magnet to the back to avoid using clips.
The sensor will detect the correct height for the glass bed. I’m not so sure about the automatic z offset, but that really shouldn’t change if the bed mesh is calibrated.
